How do I show that a function defined by an integral is of class C1?
richyw
F(x)=\int^{2x}_1\frac{e^{xy}\cos y}{y}dy
Show that F is of class C^1, and compute the derivative F′(x).
Thm:
Suppose S and T are compact subsets of \mathbb{R}^n \text{ and } \mathbb{R}^m, respectively, and S is measurable. if f(\bf{x,y}) is continuous on the set T\times S = \{ (\bf{x,y})\; : \; \bf{x}\in T, \;\bf{y}\in S\}, then the function F defined by, F(x)=\int ... \int_S f(x,y)d^n\bf{y} is continuous on T.
Thm:
Suppose S\subset \mathbb{R}^n \text{ and } \bf{f}\; : \; S\rightarrow\mathbb{R}^m is continuous at every point of S. If S is compact, then \bf{f} is uniformly continuous on S.
I already figured out that
\int e^{xy}\cos y\;dy=\frac{e^{xy}}{x^2+1}(\sin y+x\cos y)
which was listed as a hint. My book explains how to compute the derivative, but not how to show that it is of class C^1. I need some help getting started on this one!
When you differentiate a C^k function you get a C^{k-1} function. What happens when you integrate a C^k function?
uh, I'm going to go with C^{k+1}
are you sure about that though?
If f \in C^k(\mathbb R, \mathbb R) then define g(x) = \int_1^x f(t) gt. We would like to show that g \in C^{k+1}, and hence that the (k+1) derivatives of g exist and are continuous. Well, \frac{d^{k+1} g}{dx^{k+1}} = \frac{d^k f}{dx^k} and this is continuous by assumption that f \in C^k.
For multivariate calculus, do the same argument with partials. Though here you need not do that since your function is just a map F: \mathbb R \to \mathbb R.
Now the solution is not quite straightforward: you are going to need to check that the derivative of your F(x) is continuous. You can do this using the Leibniz rule.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
