How do i solve this trig question? identities etc?
In summary, the trig question asks for the equation of a line that has a certain point (B) on it, and includes the twoterms cos(B) and 3sin(B). Using basic algebra, the equation can be solved for B using the auxillary angle method.
Dell
590
4*[cos(B) + 3*sin(B)]=1+ 2*[3*sin(39) - cos(39)]
i can get it to
cosB + 3sinB=0.08054076 using basic algebra, but how do i find a value for B
Can you think of a way to perhaps combine the sine and cosine terms of the left into a single trig function?
no, that's what i need to somehow do
One common method is to use the 'auxiliary angle method', which is to combine the sine and cosine terms into a single sine (or cosine) term of the form:
R sin (B+a).
The reason why we can write it in such a form is because this is equivalent to: (using an appropriate trig identity)
R sin(B)cos(a) + R cos(B)sin(a)
So by comparing coefficients, you can see that:
R cos a = 12
R sin a = 4
From which you can solve to find a and R. See if you can continue from there.
so we have
R cos a = 4
R sin a = 12
tan a = 3
a=71.565
R=12.65
am i meant to be saying that
R sin (B+a) = R sin(B)cos(a) + R cos(B)sin(a) ?
therefore
R sin (B+a) = 1+ 2*[3*sin(39) - cos(39)]
sin(B+a)=0.25467
sin(c)=0.25467
c=14.75
c=B+71.565=14.75
B= (-56.81)
but this doesn't come right
cos(-56.81) + 3sin(-56.81)= -1.963
where i need
cosB + 3sinB=0.8054076
Yea the reason is because i made a mistake in my post but have since edited it out, and i think you have carried through that same mistake.
Comparing the two forms:
R sin(B)cos(a) + R cos(B)sin(a) = 4cos(B) + 12sin(B)
On the left hand side, the coefficient of cos(B) is R sin(a), and on the right hand side it is 4, and so we must have:
R sin(a) = 4
And by similar reasoning,:
R cos(a) = 12
So i had originally typed the 4 and 12 in the wrong places. I guess you read my post before i got a chance to edit it out (or perhaps coincidentally made the exact same mistake haha? :P)
so...
R sin(a) = 4
R cos(a) = 12
tan(a)=1/3
(a)=18.34
R=12.65
sin(B+a)=0.25467
sin(c)=0.25467
c=14.75
c=B+18.34=14.75
B= (-3.59)
cos(-3.59) + 3sin(-3.59)= -0.81
thanks!
FAQ: How do i solve this trig question? identities etc?
How do I know which trigonometric identity to use?
Identifying which trigonometric identity to use can be tricky, but it becomes easier with practice. Some common identities to keep in mind are the Pythagorean identities, double angle identities, half angle identities, and sum and difference identities. The key is to carefully examine the given trigonometric expression and determine which identity will help you simplify or manipulate it.
What is the process for solving a trigonometric equation using identities?
The process for solving a trigonometric equation using identities involves several steps. First, you need to identify the given trigonometric expression and determine which identity can be used to simplify it. Next, apply the chosen identity to the expression and use algebraic techniques to manipulate it into a simpler form. Continue simplifying until you reach a solution or an equation that can be solved using basic trigonometry rules, such as the unit circle or special triangles.
Can I use multiple identities in one problem?
Yes, it is common to use multiple identities in one problem. This is especially useful when simplifying complex expressions or solving equations. Just be sure to keep track of which identity you have used and how it has affected the expression. Also, make sure to follow the proper order of operations when using multiple identities in one problem.
How can I check if my answer is correct?
One way to check if your answer is correct is by substituting it back into the original equation and seeing if it satisfies the given conditions. You can also use a graphing calculator to graph both sides of the equation and see if they intersect at the same point. If your answer does not satisfy the given conditions or the graphs do not intersect at the same point, then you may have made a mistake in your calculations.
Are there any tips for remembering trigonometric identities?
One helpful tip for remembering trigonometric identities is to practice, practice, practice! The more you work with them, the more familiar they will become. It can also be helpful to create flashcards or a cheat sheet with the most commonly used identities. Additionally, try to understand the logic behind each identity and how it relates to the basic trigonometric functions. This can aid in remembering and applying the identities in problem-solving.
