How do manufacturers determine the 'rated' quantities for motors?
The term "rated" for motors refers to the continuous operating conditions under which the motor is designed to function effectively, including maximum voltage, load, and temperature. Manufacturers determine these ratings based on the equipment's expected lifetime and performance under specified conditions, taking into account safety margins and tolerances. While maximum ratings are common, there can also be minimum ratings for factors like temperature and speed. The discussion highlights that exceeding these ratings can lead to operational issues, similar to how a bicycle's performance varies with speed. Understanding these ratings is crucial for ensuring reliable motor operation.
yucheng
TL;DR Summary
N/A
I'm confused with the term "rated". I checked this webpage though I am not confident about it's reliability.
Context: Motor ratings etc.
Does it mean maximum? Maximum in what regard? Heat produced/temperature? Is there a more reliable source on how manufacturers determine the 'rated' quantities? Does it take into account safety margins, tolerances etc? (I might be jumbling jargon!)
I did some searching in the IEEE standards. They describe "rating" as what the equipment is designed to operate at continuously. I would link to it so you could read it, but it requires a login.
An example of voltage rating:
Maximum design voltage-to-ground: The maximum steady-state voltage-to-ground at which the high-voltage cable termination is designed to operate continuously under normal conditions.
NOTE—It is not intended that this maximum voltage limit be applied to transient overvoltages or unusual service operating conditions where the system voltage may exceed these values for only short periods of time.
Maximum?
yucheng said:
Maximum?
Usually, but not necessarily.
A motor would have maximums for Voltage, Load, Temperature; it could also have minimum ratings for Temperature and Speed.
The 'Rating' is the operating region where the motor will meet its expected lifetime when the rest of the 'Ratings' are approximately met..
For instance a bicycle may be rated for a speed of 25mph (40kph). You can operate it slower, but at some low speed it gets so difficult to balance it falls over.
At a higher speed of 50mph (80kph) the front wheel may start to shake or the brakes may overheat and fail at a sudden stop.
Hope this helps!
Cheers,
Tom
Likes scottdave and yucheng
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
12K
