How do mass and density relate in iron blocks when volume changes?
  • Thread starter Thread starter jaan
    Confusing
In the discussion on the relationship between mass, density, and volume in iron blocks, it is established that when the volume of an iron block is doubled, its mass also doubles, but the density remains constant. Density is defined as the ratio of mass to volume, and thus, if both mass and volume are increased proportionally, the density does not change. This principle illustrates the distinction between intrinsic properties like density and extrinsic properties like mass and volume. The conversation also touches on statistical mechanics, suggesting a deeper exploration of physical situations related to these concepts. Understanding these relationships is crucial for grasping the fundamental properties of materials.
jaan
a block of iron defined by parameters mass,volume and density.when volume is doubled,the mass is also doubled;but the density of doubled volume of iron block remains the same.how do you distinguish the parameters mass and density.give any example (may be 2 or 3),so that i can understand well
thank u for taking ur valuable time.
The density is the RATIO between mass and volume, \rho_{1}=\frac{m_{1}}{V_{1}}
where \rho_{1} stands for density for the first block, m_{1},V_{1} mass and volume for block 1 respectively.
If we look at a block 2 with twice the mass of block 1, that is m_{2}= 2m_{1}, and doubled volume V_{2}=2V_{1}, the density of this block is:
\rho_{2}=\frac{m_{2}}{V_{2}}=\frac{2m_{1}}{2V_{1}}=\frac{m_{1}}{V_{1}}=\rho_{1}
that is, the densities of the blocks are equal.
iam speaking statistically
as per STATISTICAL MECHANICS APPLY UR idea and can u eloborate the physical situation.
thank u
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
