How do moment of inertia and angular acceleration affect drone propellers?
Understanding moment of inertia and angular acceleration is crucial for drone design, particularly for quadcopter propellers. Moment of inertia affects how quickly a propeller can change its rotational speed, while angular acceleration is the rate of that change. The gyroscopic effect from fast-rotating propellers also plays a significant role in stability and maneuverability. It's noted that for a hovering quadcopter, the moment of inertia is less critical than the lift-to-drag characteristics of the rotor blades. Overall, grasping these concepts will enhance the understanding of drone flight dynamics.
mxchapz
Hi,
I am building a drone for a school project and I am also looking into how it flies. Recently I have been looking into angular momentum, torque, moment of inertia and angular acceleration. However I am struggling to understand moment of inertia and angular acceleration. If possible please could you explain the two and how they would relate to the propellers of a quadcopter.
Thanks
Thank you! That helped a lot with understanding it but the wired article is very vague on how it relates to the propellers. Do you have any other links or if you know how please could you explain how it relates to propellers. (Sorry for my lack of knowledge I'm only in Year 12/Grade 11 so this is complicated stuff)
When you are dealing with a very fast rotating object like a propeller, you should be aware that there is a strong gyroscopic effect. If you are not familiar with gyroscopes and gyroscopic precession, this is the time to look at that subject. Also, see this.
A few questions for you to answer (presumably for a toy quadcopter)
  1. What is the mass for each rotor blade?https://www.physicsforums.com/account/alerts
  2. What is (roughly) the moment of inertia for each rotor blade?
  3. What is the total angular momentum for a hovering quadcopter
  4. How does this compare to an ordinary (Sikorsky-style) helicopter.
  5. How much power is used to keep the quadcopter hovering (roughly)
  6. How much rotational Kinetic Energy is in the blades at hover (roughly)
I believe you will find that the moment of inertia is far less important than the lift to drag characteristics of the rotor blades. Mostly because the answer to 3 is zero.
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
