How Do Projectile Motion Concepts Apply to Real-World Physics Problems?
  • Thread starter Thread starter pokemonstar
To determine how long a ball is in the air during projectile motion, the formula s = (1/2) a t² can be used, where 's' is the displacement and 'a' is the acceleration due to gravity. The ball's horizontal motion remains constant while vertical motion is affected by gravity, meaning horizontal and vertical motions can be analyzed separately. For a ball dropped from rest, it will take the same time to hit the ground as a projectile would when thrown horizontally. Understanding the relationship between horizontal velocity and vertical acceleration is crucial for accurately depicting the motion in diagrams. Clear application of these principles will simplify problem-solving in projectile motion scenarios.
pokemonstar
http://www.whitwellhigh.com/jcantrell/cp/conceptdev/cpcd0501.pdf
I'm looking at only the 1st page of the pdf file above
#1 How do i figure out the # of seconds the ball is in the air?
I have to draw the positions...so how do i know how many meters it is after 1 second?
for #2 should the ball be touching the ground after 4 seconds? how do i know how steep to draw the curve?
how can i explain the question to #2 (motion affected by horizontal/vertical)
I'm probably looking too much into this. Someone please explain :x
Did you see the formula s = (1/2) a t2 before?
#2 will become much easier once you start with the last part of the question (how do the horizontal and vertical motion affect each other?). The answer, which you are going to remember for the rest of your (educational) life, is: they don't. The ball just keeps going horizontally at the same speed, no matter what the vertical motion is. So if you want to solve a physical problem, you can use two completely separate sets of equation (for uniform motion horizontally, and for uniformly accelerated motion due to gravity in the vertical direction).
Will that get you started?
first off, thank you for your response! =)
the formula my class got from my teacher was x(t) = 1/2 a \Deltat^2 + Vo\Deltat + Xo
so...i don't know. I'm a bit confused she didn't explain any of the equations she gave us thoroughly..
from what I'm getting from you. I plugged in x = 1/2 (10m/s^2) (1s) which gives me 5 m/s
since 1cm:5m I drew the ball falling down every 1 cm. I said the ball was in the air for 16 seconds, I don't know how to mathematically display that.
I got 1cn/s (1/16cm) but that's giving me 1/16th of a second.
For #2 I drew the ball curving down at 1cm/s since you said the speed is not affected whether going straight down or being thrown. is that what you meant?
Thanks so much
The basic equation for motion with constant acceleration using time is x\left(t\right)=x_0+v_0t+\frac{at^2}{2}.
x0= the initial position
v0= the initial velocity
a = the acceleration
t = the time
This gives us the position after a certain time t. x0 is where the object starts. (v0+at/2)t gives us the displacement due to the velocity.
For two dimensional motion (without air resistance), use the parametric equations:
x\left(t\right)=x_0+v_{0x}t
y\left(t\right)=y_0+v_{0y}+\frac{at^2}{2}
use d=0.5a(t)^2
the ball should fall to the ground from being dropped in the same time it would take the projectile to hit the ground. You know d (displacement) and a (acceleration due to gravity)
for how many metres after 1 sec sub in 1 for time
horizontal velocity is constant. Vertically there is acceleration. so one point to another going directly horizontally they should be the same distance. Going straigght down however the distance should be increasing.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
