How Do Reactions Continue at Equilibrium and What Determines Their Completion?
  • Thread starter Thread starter Null_
    Equilibrium
The discussion centers on understanding chemical equilibrium and the ongoing nature of reactions at this state. It emphasizes that reactions do not stop at equilibrium; rather, the rates of formation of products and reactants are equal. To demonstrate that reactions continue during equilibrium, Le Chatelier's principle is referenced, highlighting that removing products will shift the equilibrium to produce more. Additionally, using isotopes, such as deuterated water, allows for tracking the exchange of components in a reaction without disturbing the equilibrium, providing evidence of ongoing reactions. The conversation also touches on advanced methods to observe single molecules in dynamic systems, revealing fluctuations and transitions between states, further confirming that reactions persist even at equilibrium.
Null_
How do we know that the reaction continues during equilibrium? My textbook just gives the definition of equilibrium but offers no proof that the reaction has not stopped.
And why do some reactions go to completion but others don't? How can you tell if a rxn will go to completion or merely equilibrium?
Chemistry news on Phys.org
Reactions don't ever "stop" at equilibrium; products and reactants are just forming at a rate exactly equal to each other.
You could show that the reaction is still ongoing by LeChatelier's principle. If you remove one of the product, more will form.
One way to show that reactions keep going on at equilibrium is to add different isotopes that essentially behave identically to the other species, but can be distinguished by their mass. For example, if you consider an acid/base reaction:
A- + H+ <--> HA
You can add deuterated water (D2O) to the reaction without disrupting the equilibrium. After some time, you will find some amount of deuterated acid, showing that A is constantly exchanging hydrogens with the environment.
In certain systems, it is possible to follow the dynamics over time of a single molecule. In these systems, you can directly observe the fluctuations of a system at equilibrium. For example if a molecule can exist in one of two different states, you will see the single molecule stochastically transiting between the two different states.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
