How Do Rotational Dynamics Affect Mechanical Systems?
The discussion revolves around several problems related to rotational dynamics and mechanical systems. Participants are analyzing scenarios involving a merry-go-round's angular velocity change, tension in cables lowering a gang plank, energy generation from a super flywheel, and the work required to accelerate a beryllium sphere. Clarifications are sought regarding the definitions of tension and electrical energy in the context of rotational motion. Additionally, there is a focus on calculating work, force, and energy associated with rotational systems, with users sharing their attempts and seeking guidance on the correct equations to use. The conversation highlights the complexities of applying rotational dynamics principles to practical problems.
tcin06
1. Judy rides a 2m radius merry-go-round near its edge. Judy has a mass of 100 kg and the merry go round has a mass of 200 kg and rotates at 1 rad/s. What will the new angular velocity of the merry go round be if judy moves 45 percent of the way towards the center?
2.How much tension exists in each of two cables used to lower a 10 m long, 500 kg gang plank to horizontal if the cables originate 2 meters above the planks hinges on the ship?
3.How much electrical energy could be generated by a 672 kg super flywheel spinning at 150,000 rpm if it has a radius of 3 m and is in the shape of a disk?
4.You want to roll a 2 m beryllium sphere 10 meters while speeding it up from rest to a velocity of 103 m/s. The density is 1848 kg/m^3
A)How much work (NM or joules) would this take?
B)What force would be required?
C)How much of the force was required to do the transitional work?
D)Rotational?
E)How long (time)
I've used moment of intertia but I'm missing the in between steps, these have given me some trouble over the last few days
bump. sorry if that's not allowed
first show some attempts.
i've been working on these today and I am getting closer, i worked out the first one
for the second one what are they referring to when they say find the tension is that just the force required or what?
for the third when they say electrical energy do they mean gravitational potential energy? or what. because throughout this chapter and book we haven't learned an electrical energy equation that relates to rotational motion
and I am still completely lost on the fourth
for the energy of the wheel I've calucated w and I, w=15700 rad/s and I=3024, but i don't get what to do next, no other information is given so I am wondering if its just an equation i need or what
for the energy of the wheel question i used KErot. 1/2*3024*(15700)^2 and got 3.726E11 Joules, does that seem right?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
