Medical How do severed capillaries get re-joined on their own after an injury?
  • Thread starter Thread starter PainterGuy
The discussion centers on the body's remarkable ability to heal after an injury, particularly how it reconnects severed capillaries, arteries, and tissues without external intervention beyond stitches and antibacterial treatment. The healing process is described as an intelligent biological function, where cells secrete hormones that promote the growth of new blood vessels and adapt to changes in blood flow. While major structures like nerves and large blood vessels may require surgical reconnection, smaller injuries typically heal effectively on their own. The conversation also highlights the importance of infection prevention for optimal healing and notes that the body continuously regenerates tissues, including skin and bone. Overall, the dialogue emphasizes the complexity and efficiency of biological healing compared to mechanical repairs.
PainterGuy
Hi,
When a person gets an injury and the skin gets ruptured. The cut is only stitched and some antibacterial ointment and medicine is given so that the infection doesn't develop and the wound can heal properly.
When skin is injured; suppose a person receives a deep cut. There is so much under the skin. There are capillaries network and arteries which supply blood to the cells. There are tissues which bind the skin together and so much more. But they only put the stiches on and the skin or human body knows on its own how to re-connect the severed capillaries and arteries, and the tissues etc. together again. I find this quite amazing. Even when a pipe is broken, one first needs to align the broken parts and then put on some glue to fix it!Could you please elaborate on it a little?
I apologize for making it so informal and possibly quite incorrect but it's been years since I read biology! Thanks for your help, in advance!
Biology news on Phys.org
The small stuff simply re-grows. All the time. Even bone.
Life and living organisms ain't no machine. :smile:
The readaption isn't necessary, unless the severed stuff is either a major nerve or a major lymphatic vessel, an artery of more than a few mm diameter, or a big-ish vein.. Those should and normally will be reconnected whenever possible.
When there's a dearth of blood, cells secrete paracrine hormones that lead to capillaries growing there. And when capillaries have to funnel too much blood, they grow bigger, becoming arterioles, Or minor arteries, etc. etc. And the now-dead-ends atrophy.
But even in the case of major destruction - e.g. a complete axillar dissection, or the removal of a complete lymph node for biopsy, both of which happen not-so-rarely in cancer surgery - the lymphatic ducts will often eventually reconnect. Not always, but amazingly often. If they don't the distal part will have to be treated (i.e. bandaged, or with a compression sleeve or stocking) to prevent lymphatic edema.
In the OP the (skin) cuts are made along existing featureless zones, where no relevant structures are, and hence none will be destroyed. In internal organs those structures are used, too, where existent and possible.
On the nitpicky side: I do hope your surgeon does more than "just stitch it" when the need is there. Typically in the case of ragged cuts, there should be some debridement, too. Also, the infection prevention not only is necessary to prevent the infection itself, but also is relevant for good healing per primam intentionem. If an infection occurs, that is given priority, and defective healing will be caused: The granulocytes will form a palisade against the infected area, attract fibroblasts which then, under the influence of the granulocytes' paracrine hormones, will surround it with cartilagineous tissue. Best observable in an abscess.
HTH
Likes PainterGuy, jim mcnamara, berkeman and 2 others
Thanks a lot for a very informative answer. So, it's good to know that living organisms are are more of intelligent biological machines with the inherent ability to repair and make fixes to themselves on their own! :smile:
I don't think they will ever "rejoin". Your body just makes new capillaries as need during the healing process. This sort of thing is happening all the time.
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) The structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
