MHB How Do the Fractions A and B Differ in Value and Structure?
  • Thread starter Thread starter Albert1
    Compare
The fractions A and B are defined as A = (√998 + 9) / (√998 + 8) and B = (√999 + 9) / (√999 + 8). A comparison shows that A is greater than B. The analysis involves substituting x = 998 and simplifying the expressions, leading to the conclusion that A - B is positive. This indicates that A has a higher value than B due to the properties of square roots and the structure of the fractions. Thus, A > B is established through mathematical reasoning.
Albert1
A=$\dfrac {\sqrt {998}+9}{\sqrt{998}+8}$
B=$\dfrac {\sqrt {999}+9}{\sqrt{999}+8}$
Please compare A and B
Mathematics news on Phys.org
My solution:
If we let $f(x)=\dfrac {\sqrt {x}+9}{\sqrt{x}+8}$, differentiate it w.r.t $x$ we get $f'(x)=\dfrac {-1}{2\sqrt{x}(\sqrt{x}+8)^2}$, i.e. $f'(x)<0$ for all real $x$, or more specifically, $f'(x+1)<f'(x)$ and this implies $f(x)>f(x+1)$, hence, we can say that $A=f(998)=\dfrac {\sqrt {998}+9}{\sqrt{998}+8}>B=f(998+1)=\dfrac {\sqrt {999}+9}{\sqrt{999}+8}$.
$ let \,\,x=998$
$A-B$ = $\dfrac{1}{(\sqrt {x}+8)(\sqrt{x+1}+8\big)}\times \big [(\sqrt{x}+9)(\sqrt{x+1}+8\big)- (\sqrt{x+1}+9)(\sqrt{x}+8\big )\big ]$
=$\dfrac{1}{(\sqrt {x}+8\big)(\sqrt{x+1}+8 \big)}\times (\sqrt {x+1} -\sqrt {x}\big)>0$
$\therefore A>B$
Hello, Albert!
$A\:=\:\dfrac{\sqrt {998}+9}{\sqrt{998}+8}$
$B\:=\:\dfrac{\sqrt {999}+9}{\sqrt{999}+8}$
\text{Compare }A\text{ and }B.
Let x = 998
. . . . . . . . . . . . . . . . A \:\gtrless\:B
. . . . . . . . . . . \frac{\sqrt{x}+9}{\sqrt{x}+8} \;\gtrless\;\frac{\sqrt{x+1}+9}{\sqrt{x+1}+8}
\left(\sqrt{x}+9\right)\left(\sqrt{x+1}+8\right) \;\gtrless\;(\sqrt{x}+8)(\sqrt{x+1}+9)
\sqrt{x(x+1)} + 8\sqrt{x} + 9\sqrt{x+1} + 72
. . . . . . . . . . . . \gtrless\:\sqrt{x(x+1)} + 9\sqrt{x} + 8\sqrt{x+1} + 72
. . . . . 8\sqrt{x} + 9\sqrt{x+1} \:\gtrless\:9\sqrt{x} + 8\sqrt{x+1}
. . . . . . . . . . . .\sqrt{x+1} \;{\color{red}&gt;}\; \sqrt{x}
\text{Therefore: }\:A \:&gt;\:B
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
