How do we calculate the temperature of a laser-heated substance?
  • Thread starter Thread starter Pericle
    Temperature
The discussion focuses on calculating the temperature change of maple syrup when heated by a laser. The initial power of the laser is 100mW, reducing to 40mW, indicating an energy absorption of 0.6J/s. The user initially miscalculated the mass of the syrup and later corrected it to 3.85 x 10^-7 kg, leading to a temperature change of about 37K. Specific heat is necessary for the calculations, and it is noted that during continuous exposure, the temperature will rise until energy loss matches the energy input from the laser. The conversation emphasizes the importance of accounting for both energy absorption and heat radiation in the calculations.
Pericle
Knowing that laser beam before going through a cell with a 100µm layer of syrup has a power of 100mW and after going through a cell has 40mW, calculate what is the temperature of a syrup in a point where laser beam went through it?
Temperature of syrup before being heated is 25°C
Radius of the beam is r=0.35cm
Density of a syrup is d=1.08g/l
𝑃_𝑏/𝑃_𝑎
Q=mcT
P=πr[SUP]2[/SUP]
M=P*H*d
P_b/P_a =0.4
I have calculated mass of the syrup which is 0.42g
We know that the power of a laser before is 100mW and after is 40mW, that means that the energy absorbed by the syrup is equal to 0.6J/s.
I'm not really sure what to do here, the substance through which laser is going is Maple syrup, but I don't know any properties of it and I guess I can only make an assumption about them.
Do i just now only need specific heat?
How do i deal with heat that radiated away?
If you know that the energy absorbed by the syrup is 0.6 J/s how many Joules are deposited by the beam when the syrup is zapped by the laser? (Hint: How long does it take the beam to go through the layer?) That number is your Q in the equation. Yes, you will need the specific heat. You can also assume that the process happens fast enough so that you don't have to worry about heat being radiated away.
Likes Charles Link
Continuous laser ? Exposure time ?
It is a continuous exposure.
I have also made a mistake, because 0.06J is absorbed only.
I got the mass wrong i think. It is supposed to equal 3.85•10-7
Then the change in temperature is about 37K which actually makes sense
It's 0.06/(3.85•10-7•4200)
You said in your last post
0.06J is absorbed
. Did you intentionally change from the
J/s
units you used originally?
If it is a continuous exposure, the temperature will continue increasing until it radiates away energy at the same rate the laser is delivering energy.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
