MHB How do we get the approximation?
  • Thread starter Thread starter evinda
    Approximation
The discussion focuses on approximating the derivative \( y'(t^n) \) using different methods, specifically the forward and backward Euler methods. The forward Euler method is derived from the difference quotient \( \frac{y(t^{n+1}) - y(t^n)}{h} \), while the backward Euler method uses \( \frac{y(t^n) - y(t^{n-1})}{h} \). There is a debate about whether to choose \( h \) as negative for the backward method, with a consensus that \( h \) should remain positive. The iterative process to find \( y(t^n) \) starts with an initial estimate and updates using \( y_{n}^{[i+1]} = y(t^{n-1}) + h f(t_{n}, y_{n}^{[i]}) \). This approach emphasizes the necessity of iteration to accurately approximate the derivative.
evinda
MHB
Hello! (Wave)
Approximating $y'(t^n)$ at the relation $y'(t^n)=f(t^n,y(t^n))$ with the difference quotient $\left[\frac{y(t^{n+1})-y(t^n)}{h} \right]$ we get to the Euler method.
Approximating the same derivative with the quotient $\left[\frac{y(t^{n})-y(t^{n-1})}{h} \right]$ we get to the backward Euler method
$$y^{n+1}=y^n+hf(t^{n+1},y^{n+1}), n=0, \dots, N-1$$
where $y^0:=y_0$.
In order to find the formula for the forward Euler method, we use the limit $\lim_{h \to 0} \frac{y(x_0+h)-y(x_0)}{h}$ for $x_0=t^n, h=t^{n+1}-t^n$.
In order to find the formula for the backward Euler method, could we pick $h=t^{n-1}-t^n$ although it is negative?Or how do we get otherwise to the approximation:$$y'(t^n) \approx \frac{y(t^n)-y(t^{n-1})}{h}$$
Mathematics news on Phys.org
Hi! (Wave)
We should still pick $h$ positive.
I previously explained to http://mathhelpboards.com/members/mathmari/ how to find that derivative in this thread. (Thinking)
I like Serena said:
Hi! (Wave)
Could you explain it further to me? (Thinking)
Since we don't know $y(t^n)$ yet, we need to iterate to find it. (Thinking)
We start with an initial estimate:
$$y_n^{[0]} = y(t^{n-1})$$
And then we can iterate with:
$$y_{n}^{[i+1]} = y(t^{n-1}) + h f(t_{n}, y_{n}^{})$$
(Wasntme)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
