How Do You Adjust Camera Settings for Post-Sunset Photography?
  • Thread starter Thread starter kmj9k
    Optical
To adjust camera settings for post-sunset photography, it's crucial to understand the relationship between shutter speed and aperture in maintaining exposure. After sunset, the scene's brightness decreases to one third, necessitating adjustments to either shutter speed or f-stop. If the aperture remains at f/11, the shutter speed must be changed to 1/375 seconds to achieve the same exposure. Conversely, if the shutter speed is kept at 1/125 seconds, the f-number must be adjusted to a larger value to compensate for the reduced light. Understanding these principles allows photographers to effectively capture images in low-light conditions.
kmj9k
You are taking pictures of the beach at sunset. Before the Sun sets, a shutter speed of 1/125 s at f/11 produces a properly exposed picture. Shortly after the Sun sets, however, your light meter indicates that the scene is only one third as bright as before.
(a) If you don't change the aperture, what exact shutter speed will produce a picture with the same exposure?
(b) If, instead, you keep the shutter speed at 1/125 s, what exact f-number will produce a picture with the same exposure?
2. f-number = focal length / Diameter of aperture
3. I'm not sure what the significance of the picture being 1/3 as bright after the sun sets is. But, I do know that when you change the shutter speed, you need to change the area of the aperture to compensate if you want to maintain the same exposure. Other than that, I don't know where to start on this problem. I would appreciate any help!
hmmm. To maintain same exposure level I would think require having same number of photons strike the film in each case. Assuming "brighness" here is a measure of the number of photons that strikes the film, how much time to capture the same number as before. Remember shutter speed is a usually a small fraction of a second, 1/125 is 80 millseconds open time.
Same principle applies for next question. How much larger would opening of aperture have to be to collect the same number of photons as in original case.
Yes, I understand that part...you want the same amount of light / photons. I thought the answer to (a) might be 1/375, to make the shutter speed 3x faster so that less light is able to get in and the photo is 1/3 as bright. But, I know that's wrong...
yea, that's why I inverted the "shutter speed" to msec open time. Triple the open time, then take reciprocal to get shutter speed..
OK, inverting the shutter speed makes it much more easy to understand! I get the problem now and got the right answers. Thank you very much for your help!
No problem, happy to be of help.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
