How Do You Calculate Capacitance for Different Types of Capacitors?
  • Thread starter Thread starter mmattson07
    Capacitor
The discussion centers on calculating the capacitance of a spherical capacitor with given radii and converting the result to picofarads. The initial calculation yields a capacitance of approximately 3.984e-11 F, which is incorrectly converted to 0.3984 pF. Clarification is provided that the correct conversion should yield 39.84 pF instead. Additionally, the participant seeks to determine the plate area for a parallel-plate capacitor with the same capacitance and plate separation. Accurate unit conversion and understanding of capacitance formulas are emphasized throughout the discussion.
mmattson07
The plates of a spherical capacitor have radii 30.3 mm and 33.1 mm. (a) Calculate the capacitance in picofarads. (b) What must be the plate area in square centimeters of a parallel-plate capacitor with the same plate separation and capacitance?
C= 4\Pi\epsilon(ab/b-a) (Spherical Capacitor)
C=\epsilonA/d (Parallel Plate)
a)
I am having trouble with the conversion to pF. I know it's 10^-12.
=>C= 4\Pi\epsilon((.0303*.0331)/(.0331-.0303))=3.984e-11 F = .3984 pF ??
b) =>A=Cd/\epsilon = 3.984e-11 F(.0331-.0303)/8.85e-12
Thanks!
You made a mistake in conversion:
<br /> 10^{-11} \, \mathrm{F} = 10^{1 - 12} \, \mathrm{F} = 10^{1} \, 10^{-12} \, \mathrm{F} = 10 \, \mathrm{pF}<br />
Still confused...how do I convert then? Is it 3.984e-12 pF??
Or 39.84 pF?
mmattson07 said:
Or 39.84 pF?
yes.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
