How Do You Calculate Eigenvalues for a 2x2 Symmetric Matrix?
  • Thread starter Thread starter ilikephysics
    Eigenvalues
To calculate the eigenvalues of a 2x2 symmetric matrix A, the correct approach involves solving the quadratic equation derived from the determinant, specifically (a-λ)(c-λ) - b² = 0. The initial assumption that the eigenvalues can be directly equated to a-b and c-b is incorrect; instead, the quadratic formula should be used to find the eigenvalues. The discussion also highlights the importance of avoiding algebraic errors when working with eigenvalues and eigenvectors. The eigenvectors corresponding to the eigenvalues can be determined after correctly identifying the eigenvalues. Proper understanding of the quadratic equation is crucial for accurate calculations in linear algebra.
ilikephysics
Find the eigenvalues and eigenvectors of the general real symmetric 2 x 2 matrix A= a b
b c
The two eigenvalues that I got are a-b and c-b. I got these values from this:
(a-eigenvalue)(c-eigenvalue)-b^2=0
(a-eigenvalue)(c-eigenvalue) = b^2
(a-eigenvalue)= b = a-b
(c-eigenvalue)= b = c-b
Will there be 4 eigen values instead of the two that I have? Like, a-b and a+b and c-b and c+b?
I haven't gotten to the eigenvectors yet. I'll post what I have in a minute.
Thanks for your help
eigenvectors
Are these the eigenvectors?
For a-b,
-1
c-a-b
For c-b,
a-c-b
For the eigenvalues, you can't quite perform one of the steps you did. It's an incorrect assumption that
a - r = b = c - r
where r is an eigenvalue.
You've got the right equation up until that point, i.e.,
(a-r)(c-r) - b^2 = 0
but this is a quadratic equation in the r variable. Solve it the way you would normally solve a quadratic equation! Nothing too fancy.
cookiemonster
If you are working with eigenvalues and eigenvectors it would be a really, really good idea not to mess up basic algebra!
You have:
You appear to be thinking that if xy= b^2, then x= b and y= b.
That is not at all true! (9*1= 32;5*(9/5)= 32, etc.)
Once you have the equation (a-eigenvalue)(c-eigenvalue) = b^2
(I'm going to use λ for the eigenvalue)
(a- &lamda;)(c-&lamba;)- b2= 0
λ2-(a+c)&lambda+ (ac- b2)= 0
Now you can use the quadratic formula to solve for the two values of λ
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
