How Do You Calculate Half-Life from an Exponential Decay Equation?
  • Thread starter Thread starter fuzzybear
    Half life Life
To calculate half-life from the exponential decay equation Y=Ae^(-t/λ), the half-life can be expressed as t(1/2) = ln(2)/λ. The discussion highlights the challenge of incorporating the initial amount A into the half-life equation. By manipulating the equation A/Ao = e^(-λt), one can derive a relationship for λ. Ultimately, the half-life can be expressed as t(1/2) = ln(A/Ao)/λ, maintaining the dependence on both A and λ. This provides a comprehensive understanding of how to relate half-life to the initial amount and decay constant.
fuzzybear
Given Y=Ae-t/(lambda) find the half life in terms of A and lambda
Y=Ae-t/(lambda)
every time t is a multiple of lambda the relationship then becomes (lambda(n)=A/e^n), i can't figure out how that will relate, i also tried setting the equation to A/2 however that just canceled out the A. Need help!
I figured it out t(1/2)=ln(2)/lambda, however i don't know how to incorporate A into this
Expression of radioactive is written as
A = Ao*e^-λt...(1)
As you have mentioned
t_1/2 = ln(2)/λ.
The equation (1) can be written as
A/Ao = e^-λt. or
Ao/A = e^λt
Take logarithm of both the side and fine the expression for λ. Put it in the t_1/2 equation.
rl.bhat if i put the expression into lambda in the t_1/2 equation then i lose the lambda, i need to express it in lambda and A
In that case
t_1/2 = ln(A/Ao)/λ
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
