How Do You Calculate Particle Probability in a Quantum State?
The probability of finding a particle in the ground state between L/2 and 2L/3 is calculated using the integral of the square of the wave function, resulting in an answer of approximately 30.44%. The integral involves evaluating the sine squared function within specific limits, which can lead to errors if not calculated correctly. Users noted that common mistakes include sign errors when applying the limits of integration. After verification, it was confirmed that the correct answer is indeed around 30%. Accurate calculations are essential to avoid discrepancies in results.
Ayham
What is the probability that a particle in the ground state will be found between L/2 and 2L/3?
im new guys so go easy :)
∫ψ(x)^2 dx = ∫2/L (sin(πx/L))^2 dx
in attachment
The answer should be 30.44%
i got 66.66% and sometimes a negative number
please show me the steps too :/
So you have the integral:\int{\psi \psi^{*} dx} = \int^{\frac{L}{2}}_{\frac{2L}{3}}{\sqrt{\frac{2}{L}} \sin{\frac{n \pi x}{L}} \sqrt{\frac{2}{L}} \sin{\frac{n \pi x}{L}} dx} = \int^{\frac{L}{2}}_{\frac{2L}{3}}{\frac{2}{L} \sin^{2}{\frac{n \pi x}{L}} dx} You can get the integral of sine squared from an integral table:\int{\sin^{2}{ax} dx} = \frac{x}{2} - \frac{\sin{2ax}}{4a} Keep in mind that both \frac{x}{2} and \frac{\sin{2ax}}{4a} are evaluated at the limits of integration.
Doing all of this I obtained 30% for the answer when I plugged in n = 1 (for the ground state).
You're probably just messing up the minus sign on one of the 4 terms that come about when you evaluate the \frac{x}{2} - \frac{\sin{2ax}}{4a} term at the limits of integration. You 4 terms should be \int{\psi \psi^{*} dx} = \frac{2}{L} (\frac{L}{3} - \frac{L}{4} - \frac{\sin{(2\frac{n \pi}{L}\frac{2L}{3}})}{4 \frac{n \pi}{L}} + \frac{\sin{(2 \frac{n \pi}{L} \frac{L}{2}})}{4 \frac{n \pi}{L}})
Edit*** After a 3rd check, when n = 1 the answer is indeed 30%. Looks like we are both susceptible to math errors on this one >_< (I had edited my post thinking the answer was 60% when I double checked my original answer...)
I love you :')
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
