How Do You Calculate Position from Velocity at Time t?
In summary, "find the position at time t" refers to determining the location or coordinates of an object at a specific time t. This can be calculated using the kinematic equation for displacement, and can be found for any object as long as its initial position, velocity, and acceleration are known. The position at time t is different from the average position, as it is a specific location at a particular time, while the average position is the average of all positions over a period of time. The accuracy of determining the position at time t can be affected by factors such as measurement errors, uncertainties in initial conditions, and external forces acting on the object.
karush
MHB
3,269
$\tiny{205.o27.12 }$
$\text{Given the velocity $v=\frac{ds}{dt}$}$
$\text{and the initial position of a body moving along a
coordinate line,}$
$\text{find the body's position at time t}$
\begin{align}
\displaystyle
v&=\sin\left({\pi t}\right) &s(0)&=20 \\
v'&=\cos{(\pi t)} \\
s(t)&=
\end{align}
$\text{lost.. } $
I think it's like this:
$$s(t)=\int\sin(\pi t)\,\text{d}t=-\frac1\pi\cos(\pi t)+C$$
$$s(0)=-\frac1\pi+C=20\implies C=20+\frac1\pi$$
$$s(t)=-\frac1\pi\cos(\pi t)+20+\frac1\pi$$
so \(\displaystyle s'(t)=v(t)\)
FAQ: How Do You Calculate Position from Velocity at Time t?
What does "find the position at time t" mean?
"Find the position at time t" refers to determining the location or coordinates of an object at a specific time t. This can be in terms of distance, direction, or both.
How is the position at time t calculated?
The position at time t is typically calculated using the equation x = x0 + v0t + ½at2, where x0 is the initial position, v0 is the initial velocity, a is the acceleration, and t is the time elapsed. This equation is known as the kinematic equation for displacement.
Can the position at time t be found for any object?
Yes, the position at time t can be determined for any object as long as its initial position, velocity, and acceleration are known or can be measured. This applies to both stationary and moving objects.
How is the position at time t different from the average position?
The position at time t is a specific location of an object at a particular time, while the average position is the average of all the positions of an object over a period of time. The position at time t can change as an object moves, while the average position remains constant unless the object's position changes significantly.
What factors can affect the accuracy of determining the position at time t?
The accuracy of determining the position at time t can be affected by various factors such as measurement errors, uncertainties in initial conditions, and external forces acting on the object. Factors such as air resistance, friction, and human error can also contribute to inaccuracies in determining the position at time t.
