How Do You Calculate Resistance and Current in a Carbon Block Using Ohm's Law?
To calculate the resistance of a carbon block, the formula R = pL/A is used, where p is resistivity, L is the length, and A is the cross-sectional area. The block measures 3cm in length with a square cross-section of 0.5cm by 0.5cm, leading to an area of 0.25cm². With a potential difference of 8.4V applied, users seek to determine both the resistance and the current through the block. Clarification on the block's shape, described as a cuboid, aids understanding of the problem. This discussion emphasizes the importance of visualizing the geometry for accurate calculations.
LeakyFrog
A block of carbon is 3cm long and has a square cross section whose sides are .5cm long. A potential difference of 8.4V maintained across its length.
a)What is the resistance of the block?
b)What is the current in this resistor?
R=pL/A
I'm fairly certain i can solve this problem right quick if I could understand what exactly the block looked like. The description just doesn't make sense to me. I'm not sure if you can draw pictures on this or not but a picture would be helpful if someone can make one. Thanks.
From what I've read the block is a cuboid. Imagine a square that's 0.5cm by 0.5cm, now stretch that back in the third dimension by 3cm, and Bob's your uncle. A similar shape to a packet of gum.
thanks dude (or dudette)! helped a bunch!
No worries mate.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
