How Do You Calculate the Angular Momentum of a Rotating Bat?
To calculate the angular momentum of a rotating bat, the moment of inertia must be correctly determined. The bat should be approximated as a long thin cylinder rather than a point mass at the end. The correct formula for moment of inertia is I = (1/3)mr^2 for a rod rotating about one end. Using this, the angular momentum can be calculated with L = Iω, where ω is the angular velocity. Properly applying these formulas leads to the correct solution for the problem.
Exustior
A batter swings a 0.9 m long bat. Calculate the angular momentum of the bat relative to its axis of rotation. Assume the bat has a mass of 0.6 kg and rotates at 3 rad / s
(Hint: Approximate the bat by a rod, or a long thin cylinder, and find the moment of inertia.)
Answer in (N m)
I=mr^2
ω=v/r
v=ωr
L=Iω
L=Iω
I=mr^2
so L=(0.6)(.9^2)(ω)
ω=angular velocity is 3 rad/s
so L=(.6)(.9^2)(3rad/s)= Wrong answer
Hey, welcome to physicsforums!
uh, the moment of inertia formula you have used is not correct for this problem. The inertia I=(0.6)(0.9)^2 would suggest the mass of the bat is concentrated at the end of the bat. But it looks like they want you to assume the bat is a long thin cylinder, of uniform density. So either you can look up the moment of inertia for this kind of object, or derive it yourself, if you have time.
Thanks!
I got it I was using the wrong formula.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
