How Do You Calculate the Angular Momentum of Big Ben's Clock Hands?
To calculate the angular momentum of Big Ben's clock hands, the moment of inertia for each hand is determined using the formula I = (1/3)ML^2. The minute hand, with a length of 4.5 m and mass of 94 kg, has an angular momentum of approximately 1.110375 kg·m²/s when using the correct angular velocity of 1.75E-3 rad/s. The hour hand's angular momentum is calculated similarly, using its respective values. The initial calculations were incorrect due to errors in the angular velocity for both hands. Accurate calculations yield the correct angular momentum values for both the minute and hour hands.
cdubsean
The hour and minute hands of Big Ben in
London are 2.64 m and 4.5 m long and have
masses of 69.4 kg and 94 kg respectively.
1) Calculate the total angular momentum of
the minute hand about the center point.
Treat the hand as long, thin rod. Treat “into
the clock” as the positive direction.
Answer in units of kg · m2/s.
2) Calculate the total angular momentum of the
hour hand about the center point. Treat the
hand as long, thin rod, and “into the clock”
Inertia about center point for rod is:
I= (1/3)ML^2
Lz=Iw
For Minute Hand:
I= (1/3) (94kg) (4.5m)^2 = 634.5 kg*m^2
THen
Lz = Iw = (634.5 kg*m^2) (1/60 rev/s) (2pi rad/rev) = 66.44469 kg*m^2/s
For the Hour hand I should do the same.
For both of these, the system says I am wrong, any help?
I have found my mistake...
The Inertia was right but I needed I did second part wrong.
2pi/3600s = 1.75E-3 rad/s for minute hand
2pi/43200s = 1.45E-4 rad/s for hour hand
then
(624.5kg*m^2)( 1.75E-3 rad/s) = 1.110375 for minute hand and repeat for hour hand.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
