How Do You Calculate the Angular Speed and Center Speed of a Descending Hoop?
  • Thread starter Thread starter PKay
    String
To calculate the angular speed and center speed of a descending hoop, the initial energy (Ei) is determined using the potential energy formula, yielding 1.0584 J. The final energy (Ef) is expressed as the sum of translational and rotational kinetic energy, leading to the equation Ef = 1/2 mv² + 1/2 Iω². The moment of inertia for a hoop is confirmed as I = 1/2 mr², but concerns arise regarding the axis of rotation since the hoop is not rolling about its center. The angular speed calculated is ω = 14.9 rad/s, but there is uncertainty about the correctness of this value and the method used to find the center speed. The discussion emphasizes the importance of correctly applying energy conservation principles and the appropriate moment of inertia in calculations.
PKay
A string is wrapped several times around the rim of a small hoop with radius 8.00 cm and mass 0.180kg. The free end of the string is held in place and the hoop is released from rest. After the hoop has descended 60.0cm , calculate the angular speed of the rotating hoop and the speed of its center.
K=Iω2
U = mgh
ω=v/r
I = 1/2 mr2
Ei = mgh = (0.180)(9.8)(0.6) = 1.0584
Ef = 1/2 mv2+1/2 Iω2 = 3/4(0.08)2ω2
Ei = Ef
I got ω = 14.9 rad/s (I've also tried 35 rad/s) Is my math wrong or something?
For the second part, I saw somewhere the equation was v=√gh and but I was thinking I could just use ω=v/r but since I didn't have ω I couldn't solve that one.
Hello, PKay.
I = 1/2 mr2
Is this the correct formula for a hoop?
I think so. The problem is the axis is in the middle for that equation but since it's on the side, I'm not too sure anymore.
Likes 1 person
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
