How Do You Calculate the Electric Field of a Finite Charged Slab?
  • Thread starter Thread starter tomanator
    Charge Infinite
To calculate the electric field of a finite charged slab with a charge density of rho=cx^2, one must apply Gauss's law, which involves the integral of the electric field over a closed surface. The problem specifies calculating the electric field at x=2 for a slab extending from x=-3 to x=3, infinite in the y and z directions. A suitable closed surface must be chosen for the integration, and the volume integral will be performed over this surface. Visualizing the problem with a diagram can aid in understanding the geometry involved. Properly setting up the integrals is crucial for solving the electric field calculation.
tomanator
Need to calculate the electric field at x=2 for sheet of charge that extends from x=-3 and x=3 and is infinite in y and z. charge density rho=cx^2 c is a given numerical value
integral(E.dS)= (1/epsilon)*volume integral(p dT)
I'm completely at ends even where to start! Any help would be appreciated
I would start by drawing a picture of the problem.
The integral you've given is Gauss's law. In order to solve it you need to integrate over a closed surface. So you need to think of an appropriate closed surface to integrate over. The volume integral will just be over the volume of the closed surface.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
