How Do You Calculate the Refractive Index from Water to Glass?
To calculate the angle of refraction when light passes from water to glass, use the equation n1sin(i) = n2sin(r), where n1 is the refractive index of water (4/3) and n2 is that of glass (3/2). The angle of incidence is given as 30 degrees. The discussion highlights the importance of understanding the refractive indices in relation to air. The user expresses gratitude for guidance on approaching the problem.
reyaz1
A ray of light is incident in water on a plane water-glass boundary. The angle of incidence is 30 degrees. Calculate the angle of refraction. (Refractive index of glass with respect to air =3/2, refractive index of water with respect to air = 4/3).
n1sini = n2sinr
I tried approaching it with several methods, but I am puzzled. How do you get the glass to water refractive index from the data given??
Any help would be greatly appreciated. Thank you!
Think of the definition of the refractive index.
ehild
It is not necessary to solve this problem.
You can use the relevant equation
n1sini = n2sinr
to find r. Here n1 is the refractive index of water. and n2 is that of glass.
n1sini = n2sinr
Thank you sooo much! I just needed a nod in the right direction.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
