How Do You Calculate the Rotational Inertia of a Composite Object?
To calculate the rotational inertia of the composite object consisting of a circular hoop and a square made of four thin bars, the relevant formulas for each component's inertia must be applied. The inertia of the hoop is calculated using I = mr^2, while the inertia of the rods is determined using I = 1/3 mr^2 for those perpendicular to the axis of rotation. The total rotational inertia is found by summing the individual inertias of the hoop and the rods. The user is struggling to combine these correctly, particularly with the orientation of the rods affecting their contribution. Accurate calculations are essential for determining the overall rotational inertia of the structure.
dari09
Rotational Inertia Problem--PLEASE HELP!
Figure 12-39 shows a rigid structure consisting of a circular hoop, of radius R and mass m, and a square made of four thin bars, each of length R and mass m. The rigid structure rotates at a constant speed about a vertical axis with a period of rotation of 1.0 s. Assuming R = 0.50 m and m = 3.0 kg, calculate the structure's rotational inertia about the axis of rotation
The figure is attached
I of point mass = mr^2
I of hoop = mr^2 or .5mr^2
I of rod = 1/3 mr^2
I tried to add the I of the hoop and two of the rods together (because the other two rods are parallel to the rotating axis) but nothing that I've tried really worked...
http://panda.unm.edu/Courses/Price/Phys160/p27-2.pdf"
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
