How Do You Calculate the Tension in Wires Holding a Street Light?
  • Thread starter Thread starter turtle4yj
    Force Vector
To calculate the tension in the wires holding a 150N street light, consider the vertical and horizontal components of the forces. The vertical components of the tensions in the wires must equal the weight of the light, while the horizontal components must cancel each other out. Use trigonometric functions, specifically sine and cosine, to resolve the forces based on the angles of 30 degrees and 45 degrees. Since the system is in equilibrium, the sum of the forces in both directions must equal zero. This approach will allow for the determination of the tension in each wire.
turtle4yj
A street light weighing 150N hangs from two wires as shown. One makes a 30 degree angle with the horizontal. The other makes a 45 degree angle with the horizontal. Find the tension in each wire.
(I have no clue please help!)
Try thinking of the force from each wire as the sum of a vertical component and a horizontal component (you may need some sines and cosines to do this). The object isn't moving, so all of these must balance: the vertical force from the two wires is equal and opposite to the force of gravity, and the horizontal components must cancel.
Ohh thank u!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
