B How do you calculate the uncertainty in T using graphs?
To calculate the uncertainty in T based on the given m(B-V) value, one method involves evaluating T at the extremes of the uncertainty range, specifically at m(B-V) = 1.0 and m(B-V) = 1.4. The difference between these T values provides the uncertainty range. It's important to note that if the uncertainty is significant (around 20% of the measured value), the assumption of linear proportionality may not hold, and separate calculations for upper and lower uncertainties should be performed. The discussion emphasizes the need for careful error propagation and consideration of asymmetric uncertainties when reporting results.
heavystray
i have an equation like this:
Given m(B-V)= 1.2 +- 0.2
How do you calculate the uncertainty in T? (btw, I solve T using graphs by finding the intersection point)
My idea was first to calculate T when m(B-V) =0.2, and I then calculate T when m(B-V)= 1.2 + 0.2(its uncertainty). and then find the difference between the two T. Your help would be greatly appreciated
Your attachment cannot be viewed.
ughh thanks for pointing that out, sorry!
There is the simple way -- assume that the solution for T is monotone in m(B-V). Evaluate T for m(B-V) = 1.4 and for m(B-V) = 1.0. See what the range is.
Evaluating the error range by looking at a partial derivative of T with respect to m(B-V) and then multiplying by the error bound on m(B-V) sounds like way too much work and may not even be accurate.
Take the derivative of both sides. You get something of the form:
dm(B-V) = (...) dT
where I'm too lazy to figure out the part in parentheses.
Then the error is
dT = dm(B-V) / (...)
then just let dm = 0.2
This assumes that the error is small, so that you can treat the error in T as linearly proportional to the error in m. This will fail if the error is actually not small.
Likes jbriggs444
You can invert the equation and solve for T in terms of m(B-V). Then do standard error propagation. Use
$$\frac{{e^{\frac{a}{T}} } } {{e^{\frac{b}{T}}}}=e^{\frac{1}{T}(a-b)}$$
what do you mean the for T is monotone? so the range would be divided by two right? thanks for the reply
Wait, I'm really sorry, the equation supposed to have minus one after e, that's why i can't solve for T in terms of m(B-V) numerically. sorry again for uploading the wrong eq. thanks for the reply
That makes a big difference. Thanks for the clarification.
A function is monotone if it it always increases when its argument increases. Or if it always decreases when its argument increases. If a function is monotone then it takes on its extreme values at the extreme values of its input. This is a less strict condition than "linearly proportional".
The range would not be divided by two. The uncertainty could be different on each side of the measured/computed value.
WIth an uncertainty that is nearly as much as 20% of the measured value it might be wise to discard the assumption of linear proportionality.
What is the value of T that gives m(B-V) = 1.2? I assume it is an experimental number.
if we use the above eq. when
m(B-V)= 1.2, T= 3930
when m(B-V)= 1, T= 4420
when m(B-V)= 1.4, T= 3530
so the uncertainty of T= is 4420-3530?
OR
we have to do it separately on both sides?
upper uncertainty= 3920-3530
lower uncertainty= 4420-3920
Thanks
if we use the above eq. when m(B-V)= 1.2, T= 3930
For m(B-V) = 1.2 I got T = 4960 for log base 2.51. The natural log gave me 3714 which is closer to your value of 3930.
wait, how do you find the 4960?
OR
Thanks
