How Do You Calculate the X-Component of Force from Potential Energy?
  • Thread starter Thread starter sracks
    Potential
To calculate the x-component of force from potential energy, the formula -dU/dx is used, where U is potential energy. Users are experiencing difficulties obtaining correct force values at specific positions, particularly at x = 5 cm and x = 25 cm. It is noted that the slope of the U-r graph, which represents the force, remains consistent between 20 cm and 40 cm. Participants suggest applying the same calculation method used at x = 5 cm to find the force at x = 25 cm. Accurate interpretation of the graph and careful attention to units are crucial for correct calculations.
sracks
A particle has the potential energy shown in the figure. See link below. What is the x-component of the force on the particle at x =5, 15, 25, and 35 cm?
All answers are in N
http://img111.imageshack.us/img111/4988/figure2vn4.jpg
i know i should be using -dU/dx
but i keep getting the wrong answers when x = 5 cm
I get F = 1N
Did you take into account the fact that the x-axis is marked in cm?
oh, thank you :-p
I'm actually having trouble when x = 25 cm. Is there any advice on how to figure it out?
-dU/dx means the slope of U-r graph
slope of U-r graph between 20cm-40cm are the same.
Use the same method used at x = 5 cm.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
