How Do You Calculate Work and Angle in Vector Problems?
To calculate the work done by a force on a particle, the equation W = F * d * cos(θ) is used, where F is the force magnitude, d is the displacement magnitude, and θ is the angle between them. For the given values, the resultant displacement is approximately 5.1 m and the resultant force is about 6.7 N. The angle θ can be determined using the tangent function, resulting in approximately 348.69 degrees. Plugging these values into the work equation yields a work done of approximately 33.5 joules. The discussion also includes a question about scenarios that do not involve work, highlighting the importance of understanding work in physics.
od943
PART A: A force ~F = Fx ˆı+Fy ˆ acts on a particle that
undergoes a displacement of ~s = sx ˆı + sy ˆ
where Fx = 6 N, Fy = −3 N, sx = 5 m, and
sy = 1 m.
Find the work done by the force on the
particle.
Answer in units of J.
PART B: Find the angle between ~F and ~s.
Answer in units of ◦.
PART C: An easy question but still need help:
Which of the following does not involve work?
1. A golf ball is struck.
2. A weight lifter does military presses (lift-
ing weights over his head.)
3. A professor picks up a piece of chalk from
the floor.
4. A runner stretches by pushing against a
wall.
5. A child is pushed on a swing.
a^2+b^2=c^2
F=ma
W=fcosthetad
so here's my try: i made two triangles...one out of the force vectors and another out of the displacement vectors
i found the resultant displacement vector to be 5^2+1^2=26...so 5.1 m
i found the resultant force vector by doing 3^2+6^2=45...so 6.7 N
if i plug in these numbers into the work equation of W=fdcostheta i'll get W=5.1m*6.7Ncostheta
to find theta i'll do the tantheta=1m/5m or 11.3099 degrees or 348.69 degrees when put in the correct coordinate plane...
so does W=5.1m*6.7Ncos348.69? that equals 33.5 joules.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
