Comp Sci How Do You Correctly Implement a String Input Validation Loop in C++?
  • Thread starter Thread starter Joe_K
    C++ Function
The discussion focuses on implementing a string input validation loop in C++ for a function named Menu(), which should accept user input and validate it against specific options. The user is confused about how to store the input string and return it correctly, as well as the proper syntax for the validation loop. Key issues identified include undeclared variables, incorrect comparisons between strings and integers, and missing braces in the if statement. The function is required to take no arguments and return a string, aligning with the professor's instructions. Proper implementation will ensure the user is prompted until a valid input is received.
Joe_K
I am writing a program which requires me to make and call a function: string Menu()
This function will display a message to the user. It will then accept the user's choice (as a string) and check it for validity - that is did the user enter a "1", "2", "3", "4", "Q", or "q"? If so, the string should be returned to the calling function (main()). If not, an error message should be displayed and the user should be given another change to make a choice - this should continue until the user enters a valid value.
What I am confused about is how I am supposed to take a string value from the user. Would it be correct to store this string value in a local string variable within the string Menu() function? I don't understand how I am supposed to return the string to the calling function if it is valid.
Right now, I have the function prototyped, and I have the calling statement, I just need to write the actual function code.
Would something like this be correct?
string Menu()
while (1)
if (user_value==1 || user_value==2 || user_value==3 || user_value==4 || user_value == "q" || user_value == "Q")
return user_value;
break;
else if (user_value!=1 || user_value!=2 || user_value!=3 || user_value!=4 || user_value != "q" || user_value != "Q")
cout<<"invalid choice, try again: "
cin>> userValue;
Why not Menu(&string)?
why not use the string value as the loop test?
** note: this is pseudo code not C++ code:
String menu()
String ans=""
while(ans=="") {
ans=askUser
if(ans not valid) ans=""
return ans
notice that the loop ends when the ans != "" ie the user entered a valid string
I meant to type Menu(). To myself, Menu(string) would make more sense, but for some reason the professor told us to type it like that without any arguments. Is this most likely a mistake from her end, or is there some other way to take an argument?
I doubt very much that this is a mistake. The program requirements are that this function takes no arguments, and returns a string entered by the user to the caller (main).
I see several things wrong with your code.
1) user_value is not declared.
2) userValue is not declared. Why do you have two variables with similar names when one would suffice?
3) your if statement is missing the braces - { } - for its body. In some limited cases you can omit the braces, but it's generally a good idea to include them, even when you don't have to. In your case, this causes a syntax error that the compiler will flag.
4) user_value is likely a string variable, yet you are comparing it to integer constants.
5) your break statement will never execute, since it comes after a return statement.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
