MHB How do you describe transformations in a sinusoid?
  • Thread starter Thread starter mathdrama
    Transformations
Transformations in a sinusoid are described by the amplitude, which is always a positive value, representing the distance from the equilibrium to the extrema. The amplitude is calculated as the absolute value of the coefficient in front of the sine or cosine function, regardless of its sign. For example, in the function -2 cos(3(θ + 90°)) + 1, the amplitude is | -2 | = 2. It is clarified that the amplitude cannot be negative, and any confusion regarding negative values is addressed. Understanding this concept is crucial for accurately describing sinusoidal transformations.
mathdrama
How exactly do you describe transformations? For instance, if the amplitude has gone from 1 to -2, how would you word that?
Mathematics news on Phys.org
Re: wording transformations
If you are referring to the amplitude of a sinusoid, the amplitude is a positive real number. For example, the sinusoid:
$$f(x)=A\sin(Bx+C)+D$$ where $A\ne0$
has an amplitude of $|A|$.
The amplitude is half the difference between the maximum and minimum of the function. So, if the amplitude changes, then so do the extrema.
The amplitude is never negative? I must be doing this wrong.
I had assumed the amplitude of this function: [math] - 2 cos 3(\theta + 90°) + 1 [/math] must be -2
The amplitude is the distance from the equilibrium to the extrema, and as such is a non-negative value. In the sinusoid you cite, the amplitude is defined as:
$$A=|-2|=2$$
$$A=|-2|=2$$
Oh, I understand now. Thank you very much.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
