MHB How Do You Express Vectors in a Rectangle Using Midpoint Coordinates?
  • Thread starter Thread starter karush
    Rectangle Vectors
In the discussion, participants explore expressing vectors in a rectangle, specifically using midpoint coordinates. For vector \(\overrightarrow{CD}\), it is derived as \(\overrightarrow{OD} - \overrightarrow{OC}\). The vector \(\overrightarrow{OA}\) is expressed as half of \(\overrightarrow{CD}\), resulting in \(\frac{1}{2}(\overrightarrow{OD} - \overrightarrow{OC})\). Lastly, \(\overrightarrow{AD}\) is calculated to be \(\frac{1}{2}(\overrightarrow{OD} + \overrightarrow{OC})\). The discussion emphasizes the relationships between these vectors in the context of the rectangle's geometry.
karush
MHB
View attachment 1019$$ABCD$$ is a rectangle and $$O$$ is the midpoint of $$[AB]$$.
Express each of the following vectors in terms of $$\overrightarrow{OC}$$ and $$\overrightarrow{OD}$$
(a) $$\overrightarrow{CD} $$
ok I am fairly new to vectors and know this is a simple problem but still need some input
on (a) I thot this would be a vector difference but this would make $$\overrightarrow{CD} = 0$$
(b) $$\overrightarrow{OA}$$
(c) $$\overrightarrow{AD}$$
Mathematics news on Phys.org
Re: vectors inside a rectangle
Hello, karush!
\overrightarrow{CD} \;=\;\overrightarrow{CO} + \overrightarrow{OD} \;=\;-\overrightarrow{OC} + \overrightarrow{OD} \;=\;\overrightarrow{OD} - \overrightarrow{OC}
\overrightarrow{OA} \;=\;\tfrac{1}{2}\overrightarrow{CD} \;=\;\tfrac{1}{2}\left(\overrightarrow{OD} - \overrightarrow{OC}\right)
\overrightarrow{AD} \;=\;\overrightarrow{AO} + \overrightarrow{OD} \;=\;-\overrightarrow{OA} + \overrightarrow{OD} \;=\;\overrightarrow{OD} - \overrightarrow{OA}
. . . .=\;\overrightarrow{OD} - \tfrac{1}{2}\left(\overrightarrow{OD} - \overrightarrow{OC}\right) \;=\;\overrightarrow{OD} - \tfrac{1}{2}\overrightarrow{OD} + \tfrac{1}{2}\overrightarrow{OC}
. . . .=\;\tfrac{1}{2}\overrightarrow{OD} + \tfrac{1}{2}\overrightarrow{OC} \;=\;\tfrac{1}{2}\left(\overrightarrow{OD} + \overrightarrow{OC}\right)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
