How do you find the difference in the angle of refraction?
To find the difference in the angle of refraction for orange and violet light in crown glass, apply Snell's Law, which relates the angle of incidence to the angles of refraction using the indices of refraction for each color. Given an angle of incidence of 36.7 degrees, the indices of refraction are 1.522 for orange (610 nm) and 1.538 for violet (410 nm). Calculate the angle of refraction for both colors separately using the formula sin(θ1) / sin(θ2) = n1 / n2. The difference in the angles of refraction will provide the answer to the problem. This approach clarifies how wavelength affects refraction in materials.
angiep410
Sunlight strikes a piece of crown glass at an angle of incidence of 36.7 degrees. Calculate the difference in the angle of refraction between a orange (610. nm) and a violet (410. nm) ray within the glass. The indices of refraction for the orange and the violet are n = 1.522 and n = 1.538, respectively
I know that the angle of incidence = the angle of reflection
I don't really know how to solve this with the information I'm given. I have no idea where to start. Can someone help me?
This is REFRACTION you need the relationship between Sini and Sinr
so then I'm even more confused. So I have sin(36.7)= ? How do I set it up?
This shows me that you're not quite sure what you're being asked.
In every material, the 'n' value (index of refraction) is a function of wavelength. Each wavelength in the visible range of light is received by our eyes as different colours.
The question is asking you: If a beam of white light (containing all wavelengths) strikes the glass at angle ∅, what will be the difference in the refracted angle between orange and violet.
All you have to do is apply snell's law twice (to each colour), and compare the answers.
But I'm given that the wavelength of orange is 610 nm and the indices of refraction is n = 1.522 and the wavelength of violet is 410 nm and the indices of refraction is n = 1.538. So How do I set it up if I'm given all of this information?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
