MHB How Do You Find the Length x in a Geometric Problem with Shaded Areas?
  • Thread starter Thread starter paulmdrdo1
    Geometry
To find the length x in the geometric problem with a shaded area of 1200 cm², the areas of a triangle and rectangle are considered. The triangle's area is initially set up as A_triangle = (1/2)(x-1)(x), but it is corrected to A_triangle = (1/2)x². The equation combining both areas is A_rectangle + A_triangle = 2400, leading to the equation (1/2)x² + x = 1200. Solving this quadratic equation yields x = 48 cm as the valid solution. The final answer is x = 48 cm.
paulmdrdo1
Find the length x if the shaded area is 1200 cm^2
I tried to solve this is what I get
since $A_{triangle}=(\frac{1}{2})({x-1})(x)$
and $A_{rectangle}=x$
$A_{rectangle}+A_{triangle}=2400$
Is the set-up of my equation correct?
Mathematics news on Phys.org
Why are you using $x-1$ in the area of the triangle?
I see it. $A_{TRI}=\frac{1}{2}(x^2)$
now I will have
$\frac{1}{2}(x^2)+x=2400$
solving for x $(x-48)(x+50)=0$
$x=48 in.$ :D
Well, you actually have:
$$\frac{1}{2}x^2+x=1200$$
or:
$$x^2+2x-2400=0$$
$$(x+50)(x-48)=0$$
Discarding the negative root, we then find:
$$x=48\text{ cm}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
