How do you integrate dirac delta functions?
KeithKp
∫δ(x3 - 4x2- 7x +10)dx. Between ±∞.
Well I don't really know how to attempt this. In the case where inside the delta function there is simply 2x, or 5x, I know the answer would be 1/2 or 1/5. Or for say δ(x^2-5), the answer would be 1/√5.
But I'm unsure how to go about this one. Wolfram Alpha states the answer is 1/6. Tried to factor the polynomial which results in (x-1)(x+2)(x-5). But that doesn't seem to help either.
Any guidance would be great thanks!
You are on the right track. You now know what points give a contribution (the roots of the polynomial) if they are inside your integration interval.
Now, do you remember where the factor 1/sqrt5 comes from in the case of x^2-5?
Are you saying that I should only consider the (x-5) and (x-1) roots? Would that then result in the answer being 1/6? Why would I not consider the negative root? :S
I know this relation exists:
∫dx⋅f(x)⋅δ(ax+b) = 1/|a|⋅f(-a-1b). (sorry for the formatting) (limits ±∞ again)
Which I understand makes sense for say δ(2x). Not quite sure how √5 is a in δ(x^2-5). But I get the system. Then I'm really confused for the 3 order polynomial above.
https://www.physicsforums.com/file:///page36image21544 https://www.physicsforums.com/file:///page36image21704
I can see i take the positive root for x^2-5, is that the same thinking for taking (x-5) and (x-1) above? But why is that?https://www.physicsforums.com/file:///page36image21544 https://www.physicsforums.com/file:///page36image21704
\delta(x^2-5) = \delta((x-\sqrt{5})(x + \sqrt{5})) = \delta(2 \sqrt{5} (x - \sqrt{5}) + \delta(-2 \sqrt{5}(x + \sqrt{5}))
...Thank you, I'm an idiot.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
