How Do You Simplify cos^4x Using Trigonometric Identities?
  • Thread starter Thread starter david18
    Trig
The discussion focuses on simplifying cos^4x using trigonometric identities. The user attempts to express cos^4x in terms of cos2x and cos4x by squaring the identity cos^2x = 1/2(1 + cos2x). They derive the expression 3/8 + 1/2 cos2x + 1/4 cos4x but seek clarification on how to handle (cos2x)^2. The conversation highlights the importance of using established identities to simplify trigonometric expressions efficiently. Overall, the thread emphasizes the application of trigonometric identities in simplifying complex expressions.
david18
Hi, I get stuck on the 3rd part of this question:
(i) Draw sketches of the functions sin x and sin^2x over the range -360<x<360.
(ii) Explain why, for the range 0 < x < 90=2, sin x is smaller than tan x.
(iii) Using the equality cos^2x=\frac{1}{2}(1+cos2x) or otherwise, express
cos^4xin terms of cos2x and cos4x.
My attempt at part iii:
I squared the left hand side of cos^2x=\frac{1}{2}(1+cos2x) to get cos^4x and therefore squared the right hand side as well, leaving the right hand side as \frac{1}{4}(1+cos2x)^2
I'm presuming I have to square the right hand bracket out but I'm unsure on what (cos2x)^2 becomes.
Any help would be appreciated
If you know (because it was just given!) that
cos^2(a)= \frac{1}{2}(1+ cos(2a)
for any a, then what is cos^2(2x)?
Thanks for the reply, following your method I ended up with \frac{3}{8}+\frac{1}{2}cos2x+\frac{1}{4}cos4x
Just out of interest, if I were to square cos2x would I have to use the knowledge given in the question or does it equal something obvious?
Only the "obvious" cos^4(2x)! But then you could use the same identities to reduce that. It's just easier to use the already factored form.
