How Do You Solve a Cubic Equation Using Cardano's Formula?
  • Thread starter Thread starter cscott0001
    complex analysis
cscott0001
Use Cardano's formula to find a real root for ##3x^3-45x^2+243x-525=0##. [Edited to correct mistake]
$$x = u - \frac{b}{3a}$$
Depressed cubic: $$u^3=3pu+2q$$
Cardano's formula: $$u=\sqrt[3]{q+\sqrt{q^2-p^3}}+\sqrt[3]{q-\sqrt{q^2-p^3}}$$
I have found the depressed cubic to be ##x^3=20-6x##. I found ##3p= -6## and ##2q=20 \to p=-2## and ##q=10##. Using Cardano's formula, I arrived at ##u=\sqrt[3]{10+\sqrt{108}}+\sqrt[3]{10-\sqrt{108}}##. However, I graphed the equation and know that it should be 7. If I change my answer to ##u=\sqrt[3]{10+\sqrt{108}}-\sqrt[3]{-10+\sqrt{108}}## and use this answer (2) to solve ##x = u - \frac{b}{3a}## I get the right answer (7), but I have no idea mathematically why I would do that, or how I'd arrive there. I have been staring at this for two days with little progress; where did I go wrong?
cscott0001 said:
Use Cardano's formula to find a real root for ##x^3-15x^2+243x-525=0##.
I don't know where you went wrong, but you did, indeed, go wrong. Using Maple, the solution to
$$ (1) \hspace{2em} x^3-15x^2+243x-525=0$$
is
$$-(220+4*14001^{1/2})^{1/3}+56/(220+4*14001^{1/2})^{1/3}+5 \doteq 2.476595025 $$
(together with two complex roots), while the solution of
$$(2) \hspace{2em} x^3 +6x - 20 = 0$$
is ##x = 2## (together with two complex roots).
Oh geez, that's my fault. The original equation is ##3x^3-75x^2+243x-525=0##. I gave one half with the 3 factored out and one half without the 3 factored out...
OK, so now the real root of this is
$$1/3*(8875+3*2558073^{1/2})^{1/3}+382/3/(8875+3*2558073^{1/2})^{1/3}+25/3 \doteq 21.62912601 $$
BTW: when discussing Cardano's formula you should tell us what ##a,b,c,d## stand for. I have seen different sources use different conventions!
Also, write the formulas for ##p## and ##q## in terms of ##a,b,c,d##. We can't help if we can't figure out what you are doing.
Thank you for your time, I'll try to add as much relevant detail to my question as I can (and finally state the given equation correctly). It is ##3x^3-45x^2+243x-525=0##, making ##a=3##, ##b=-45##, ##c=243##, ##d=-525##. I quadruple-checked this time!
The method we were taught was to take an equation in the form ##ax^3+bx^2+cx+d=0## and find the depressed cubic in the form ##u^3-3pu+2q=0## by substituting ##x = u-\frac{b}{3a}## and then solving ##a(u-\frac{b}{3a})^3+b(u-\frac{b}{3a})^2+c(u-\frac{b}{3a})+d=0## for ##u##. I factored a 3 out of the given equation, which gave me ##a=1##, ##b=-15##, ##c=81##, ##d=-175##, which makes the equation ##x^3-15x^2+81x-175=0##. I made the substitution of ##x = u -\frac{(-15)}{3(1)}=u+5##. Substituting this value in for ##x##: ##(u+5)^3-15(u+5)^2+81(u+5)-175=u^3+6u-20=0##. We were shown examples in class where the next step was to use this depressed cubic in the form ##x^3=3px+2q## to supply the values of ##p## and ##q##: ##u^3=20-6u##, so ##20=2q## and ##3p=-6##. I'm not sure how to write that in terms of the original equation, I did not use ##a, b, c,## or ##d## to find ##p## and ##q##. I used these values for ##p## and ##q## in Cardano's formula listed above to arrive at my thoroughly incorrect solution.
It seems you only went wrong at the very end. The evaluation of Cardano’s formula as you computed it (before fiddling with it) should be approx
2.732 + - .732 ( note: cube root of negative number -.392...). This yields the expected answer of 7 for u + 5
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
