MHB How Do You Solve the Absolute Value Equation -3|x+5| + 1 = 7|x+5| + 8?
The absolute value equation -3|x+5| + 1 = 7|x+5| + 8 simplifies to -10|x+5| = 7, leading to |x+5| = -7/10. Since the absolute value cannot be negative, this indicates a fundamental issue with the equation. Therefore, the conclusion is that there are no solutions to the equation. The negative result confirms that the equation has no valid solutions. The final answer is no solution.
mathdad
-3|x+5| + 1 = 7|x+5| + 8 Solution:
-3|x+5| – 7|x+5| = 7
-10 |x+5| = 7
|x+5| = -7/10
x+5 = ±(-7/10)
x = ±(-7/10) – 5
x₁ = -7/10 – 5
x₁ = -57/10
x₂ = 7/10 – 5
x₂ = 2/10
x₂ = 1/5
Correct?
Mathematics news on Phys.org
-10 |x+5| = 7
|x+5| = -7/10
When you reach this point, then you should observe that you have a problem...can you identify the problem?
The problem is |x+5| = -7/10. More clearly, the problem is the negative -7/10.
No solution is the answer.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
