How Do You Solve the Differential Equation dy/dt + (1/t)y = t*exp(-2t)?
To solve the differential equation dy/dt + (1/t)y = t*exp(-2t), the integrating factor needs to be determined for the left-hand side. The equation can be transformed into a separable form by expressing it as d(u(t)y)/dt = u(t)y' + (u(t)/t)y. This approach simplifies the process of finding the integrating factor, u(t). Using parentheses for clarity, such as (1/t)y, can help avoid confusion in the equation's structure. The discussion emphasizes the importance of correctly identifying the integrating factor to compute the general solution effectively.
Eggmans
Compute the general solution of the differential equation?
dy/dt+1/t y = t*exp(-2t)
y is outside 1/t
can't seem to get it
Find the integrating factor for the left hand side.
d/dt (some function * y) = ...
d(u(t)y)/dt= u(t)y'+ u'(t)y and you want that equal to u(t)y'+ (u(t)/t)y. That gives a simple separable equation for the integrating factor, u.
By the way, simpler than saying "y is outside 1/t" is to use parentheses: (1/t)y
  • · Replies 16 ·
