How Do You Solve This Differential Equation Involving Trigonometric Identities?
  • Thread starter Arman777
In summary, the student tried to solve the homework equation but could not figure out what to do next.
Arman777
Insights Author
193
##2r(s^2+1)dr+(r^4+1)ds=0##
Find the solution of the given Diff. Eqn.
s[/B]
its a separable equation.
Hence I divided both sides with ##\frac {1} {(s^2+1)(r^4+1)}## and we get
##\frac {2r} {(r^4+1)} dr+\frac {1} {(s^2+1)}ds=0##
since its in the form of ##g(r)dr+h(s)ds=0##
I can take normal integral and I get
##arctan(r^2)+arctan(s)=arctan(c)##
but from now on I didnt know what to do
I thought to write ##r^2+s=c## but answer is
##r^2+s=c(1-r^2s)## which I didnt understand where the ##(1-r^2s)## comes from ?
s[/B]
The identity
$$\tan(a+b) = \frac{\tan a + \tan b}{1- \tan a \: \tan b}$$
implies that
$$\arctan(u) + \arctan(v) = \arctan \left( \frac{u+v}{1-uv} \right)$$
I suggest that you look up the trigonometric identity for ##\tan(a+b)## expressed in ##\tan(a)## and ##\tan(b)## (or even better, derive it yourself if you are able).
Hmm, I see. I never thought that actually :/ Thanks :)
I'll try to do
Related to How Do You Solve This Differential Equation Involving Trigonometric Identities?
What is a differential equation?
A differential equation is a mathematical equation that relates a function to its derivatives. It is used to model many physical and scientific phenomena, such as motion, growth, and decay.
Why are differential equations important?
Differential equations are important because they allow us to describe and predict the behavior of complex systems. They are used in many fields, including physics, engineering, economics, and biology.
How do you solve a differential equation?
The process of solving a differential equation involves finding a function that satisfies the equation. This can be done analytically, using mathematical techniques such as separation of variables or integrating factors, or numerically, using computers to approximate the solution.
What is the difference between an ordinary differential equation and a partial differential equation?
An ordinary differential equation involves a single independent variable and its derivatives, while a partial differential equation involves multiple independent variables and their derivatives. Partial differential equations are often used to model systems that vary in space and time.
Can all differential equations be solved?
No, not all differential equations have analytical solutions. Some equations may have no solution, while others may only have numerical solutions. Additionally, the complexity of the equation may make it difficult or impossible to find a solution. In these cases, numerical methods can be used to approximate the solution.
