How do you visualise the atomic orbitals?
Understanding electron orbitals involves recognizing that they represent stationary states where the electron's position is described by probability distributions rather than fixed trajectories, as dictated by Heisenberg's uncertainty principle. Orbitals can be visualized as regions where the likelihood of finding an electron varies, with different shapes and complexities such as the Bohr model's circular shells and the more accurate SPDF configurations. The probability of locating an electron is highest at certain points within these orbitals, with specific characteristics for S, P, D, and F orbitals. The Schrödinger equation underpins the behavior of electrons, detailing quantum numbers that define energy levels, orbital types, and electron spin. For a clearer visual representation of these concepts, resources like the Falstad simulation can be helpful.
Nethrz
I do know the shapes of the individual orbitals but as a whole, I'm confused as to how to visualise their positions...Also how can we predict the trajectory of an electron or can it not be predicted because of Heisenberg's uncertainty principle
Chemistry news on Phys.org
Orbitals represent stationary states, i.e., states that do not change with time. You cannot talk about the trajectory of an electron in an orbital, only the probability that it will be found at a certain position around the nucleus.
For the purposes of chemistry, I think it is best to see it as the electron being spread out over the orbital. It is a classical picture that is not completely correct, but useful.
Likes Astronuc, DeBangis21, Nethrz and 2 others
You could imagine orbitals on different levels with increasing complexity and correctness
First would be bohr orbitals, which are the circular orbital energy shells K,L,M,N and so on where 2,8,8,18,32...goes on
Second would be SPDF configuration where orbitals are basically a certain region where probability of finding the electron is.For example the probability of finding a electron in S orbital is maximum at the centre and minimum at the edges .For P orbital a node comes in play where the probability of finding a electron is 0 and it is maximum as we go farther away but not too far away outside the orbital.Similarly for D, F etc. It is given by a probability distribution function which gives us this information
You can view this here at falstad :
https://www.falstad.com/qmmo/
All the other things about the electron are derived from the schrödinger equation except the spin quantum number. Principal quantum number tells you which energy level it lies on i.e n=1,2,3....and so on . Azimuthal quantum number tells you the orbital i.e S,P,D or F and .Magnetic quantum number tells you the subshell i.e the subshell of orbital in different axis like P(x),P(y) and P(z) .Spin quantum number tells you the spin of electron i.e +1/2 or -1/2.
As for the positions of the orbitals they overlap on and into each other creating concentric shapes which hold the electrons(according to spdf model) even if you dont understand this go to the falstad link above to visualise it ,it gives you a 3d model along with probability density
Likes DeBangis21 and Nethrz
Likes pinball1970
Likes pinball1970, PhysicsEnjoyer31415 and berkeman
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
