How Do You Write a Superposition Wavefunction for an Electron in a 1D Box?
To write a superposition wavefunction for an electron in a 1D box of length L, combine the states Ψ1(x), Ψ2(x), and Ψ3(x) using the coefficients c1, c2, and c3, resulting in the form Ψ(x) = c1*Ψ1(x) + c2*Ψ2(x) + c3*Ψ3(x). It is essential to ensure that the coefficients satisfy the normalization condition C12 + C22 + C32 = 1. The inner product of the wavefunctions can be used to verify orthogonality, which is crucial in this context. Normalizing the entire wavefunction, rather than just individual states, is necessary for proper formulation. Understanding these concepts will help in constructing the desired wavefunction.
coconutfreak
1. PROBLEM
Q: write down an expression for a superposition wavefunction \Psi(x) for an electron in a 1D box of length L consisting of the n = 1, 2, and 3 states. show that C12 + C22 + C32 = 1, and Cn represents the coefficients of the n state.
2. RELEVANT EQUATIONS
see word document. thanks.
3. MY ATTEMPT
Am I supposed to integrate or differentiate the equations at all?
I don't know how to even start this Q.
Thanks a lot for your help :)
It looks like you know the equation for the nth state. A "superposition" simply means the wavefunction is in the form c1*Ψ1(x) + c2*Ψ2(x) + c3*3Ψ(x), where c1, c2, and c3 are complex numbers.
To start on the question, write out the wavefunction and take its inner product with itself. Remember that the eigenfunctions are orthogonal. What do you get?
i don't understand..
i am so sorry..
i know how to get Ψ1(x), Ψ2(x) and Ψ3(x) by simply substituting n = 1, 2, or 3 into the wavefunction equation.
what do you mean by inner product? dot product?
but i don't know how to continue from here.
thanks a lot for your help.
Yup!
Hmm, I don't know what you've already learned, so it's kind of hard to explain. Have you seen the notation <a|b> before? That's the inner product of two functions, and it's defined as the integral of the a*b (complex conjugate of a multiplied by b).
If you haven't seen it before, no worries. Just normalize the wavefunction in the way that you usually normalize wavefunctions. However, make sure to normalize the entire wavefunction, not just the individual states.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
