How does a calibrated Hall Probe work?
  • Thread starter Thread starter Yoriko
    Probe Work
A calibrated Hall probe measures magnetic field strength (B) and requires connection to a meter for direct readings. The probe typically operates with a regulated DC voltage of 5V or 6V and outputs a differential voltage proportional to the magnetic field strength, usually between 0.2 mV and 2 mV per Gauss. Probes can vary in design, with some including built-in amplifiers and temperature compensation. Calibration accuracy is generally around ±20% unless specifically hand-calibrated. For precise measurements, users can create a small electromagnet for self-calibration if needed.
Yoriko
I'm supposed to plan an experiment using a calibrated hall probe to investigate the relationship between Magnetic field strength (B) of a coil and the distance (x) from the centre of the coil.
I'm supposed to be able to take direct readings from the calibrated hall probe to calculate B, but how to? Is the hall probe supposed to be connected to something else?
There are several implementations of the linear Hall Effect probes used for magnetic field measurement. The simplest architecture is similar to a Wheatstone bridge, with two terminals for applied voltage, and two for a differential voltage output (floating outputs). The applied dc input voltage should be a regulated voltage, usually 5V or 6V. Use a 7805 or 7806 IC regulator if necessary.The differential output voltage is usually about 0.2 mV per Gauss to 2 mV per Gauss, with an output impedance of several k-ohms. The output voltage usually has a temperature coefficient. These are 4-terminal probes. Use a floating digital voltmeter (battery operated is best) with 1 mV or better resolution, and a 10 meg input impedance.
Some linear probes have a built-in differential amplifier (with some voltage gain) with temperature compensation. These are usually 3-terminal probes, with the output voltage measured with respect to the negative input voltage terminal. For a 6V input probe, the output voltage for zero Gauss is 3V.
Unlike some other probes, like proton nuclear magnetic resonance (NMR), the Hall Effect probes are usually only about ±20% calibration, unless specifically hand-calibrated.
Bob S
Bob S
:confused: Hm I'm not taking so high level physics yet so I don't really understand. So basically the hall probe is connected to a Gauss meter so direct readings of magnetic field strength can be obtained?
It needs to be connected to a meter. Most probes are calibrated to match a given meter.
for instance:
http://www.lakeshore.com/mag/ga/gm410po.html
for instance:
Ok thanks! :smile:
You could get one of these sensors from AllegroMicro (sometimes available as a free sample) and read it out with a standard digital voltmeter:
http://www.allegromicro.com/en/Products/Part_Numbers/1301/1301.pdf
If you need an absolute calibration better than than the standard specification, make a small electromagnet and do it yourself.
Bob S
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
