I How does a free surface flow cause non-linearity?
  • I
  • Thread starter Thread starter binbagsss
    Flow
Free surface flow causes non-linearity primarily through boundary conditions, influencing flow dynamics. Thicker films exhibit greater boundary layer flow velocity, allowing surface waves to gather more fluid from thinner films, leading to breaking waves. The discussion emphasizes the mathematical aspects rather than physical explanations, prompting inquiries about specific equations involved. Reference is made to "Free-surface flow: shallow-water dynamics" by Nikolaos D. Katopodes for further insights. Understanding these dynamics is crucial for analyzing fluid behavior in various applications.
binbagsss
TL;DR Summary
Free surface flow , non linearity
How does a free surface flow cause non-linearity , is it through the boundary conditions ? Which one and how ? Thanks
Links? :wink:
binbagsss said:
How does a free surface flow cause non-linearity , is it through the boundary conditions ...
Boundary layer flow velocity is greater for thicker films. A surface wave catches up with, and collects more fluid from thinner films, until it builds into a breaking wave, that rushes across the wet surface.
in terms of the equations sorry, not physically, thanks
Which situation and which equations.
I refer you to chapters 2 and 3 of;
Title: Free-surface flow: shallow-water dynamics
Author(s): Katopodes, Nikolaos D.
Publisher: Elsevier Science & Technology, Year: 2019
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
