MarcusThatsMe
- 22
- 8
- TL;DR Summary
- The accumulated energy vs. rotations of a motor generator
I'm not a mechanical engineer, I'm just a curious mind that needs some help understanding the logic here.
I understand that a weight, say 120t granite cube elevated 50 meters has the stored energy of 16 kWh. Thus a gravity battery (Ep = m * h * g).
I'd imagine this has something to do with the conservation of energy. BUT, I'm going to ask anyway because to me these are two separate pieces.
So the granite cube falls to the ground hooked to a rope that spins some gears that in turn turns a motor generator. I get that the cube has a stored energy of 16 kWh, but how does that translate into the spinning of a shaft through a gear system to generate energy via a motor generator.
I have a mini 24v brush-less motor generator and just spinning the shaft with my finger is SUPER easy. I couldn't image that a larger scaled system would be that much different, to think that some 120t object would not be able to turn the shaft to generate more energy then 16 kWh is crazy to me.
It just doesn't compute in my head.
Is there some math or something that could put some sense to it?
