Undergrad How does a photon travel?
  • Thread starter Thread starter Green dwarf
    Photon Sun Travel
A photon does not have a well-defined position or trajectory, as it is described by quantum field theory (QFT) rather than classical physics. The concept of a photon as a particle of light is misleading; instead, it represents quantized interactions with the electromagnetic (EM) field. There is no fixed number of photons traveling through space in a classical manner, and the EM field can be approximated by classical waves obeying Maxwell's equations. When discussing photons, it's essential to understand that they are not localized entities but rather manifestations of the quantized EM field. Ultimately, the discussion emphasizes the distinction between classical and quantum descriptions of light.
Green dwarf
TL;DR
A photon takes 4 years to get from the Sun to Alpha Centauri. 2 years after setting off, is it in one place, multiple places or nowhere?
Is it at a single point half way between the two stars, or is it in a superposition of locations forming a hemispherical shell around the sun, or does it just not exist at all until it interacts with a particle in Alpha Centauri?
None of the above. A photon in QM, or more precisely in QFT since you need to use that to model photons for this scenario, has no well-defined "position" operator at all. That is simply not a concept that applies here.
Green dwarf said:
TL;DR Summary: A photon takes 4 years to get from the Sun to Alpha Centauri.
No. A beam of light takes 4 years to get from the sun to alpha centauri, but photons are something completely different.
When you hear that "a photon is a particle of light" or something similar it's natural to think that light moving through space is made up of photons the same way that a river is made up of water molecules moving along the riverbed.... but in fact that model is hopelessly misleading. As @PeterDonis says above, there is no position operator, no position operator means no trajectory, no way of saying that a photon followed this path or that path through space.
Likes gentzen and Lord Jestocost
Saying the particle has no position operator - is that different from saying it is not at any location or that it is nowhere?
You will need to define "at any location" and "it is nowhere". Also define "the particle". Then perhaps one can answer the question.
It means ‘position’ and ‘nowhere’ don’t apply.
It means that it makes no sense to apply the concept of position to it, the same way that it makes no sense to talk about the mass and electric charge of ##\pi##.
Likes phinds and Dale
Yes.
Unless ##\pi## stands for pi meson o0)
  • Haha
Likes pines-demon and PeroK
The fundamental concept (in QFT) is the quantized EM field. This is in contrast to classical physics, where the fundamental concept is a fixed number of distinguishable particles. The EM field created by a distant star has a given probability of interacting with a detector on Earth. In fact, it results in a fairly well-determined number of interactions per second - depending on the location and characteristics of the detector. Each interaction represents a "photon", which is the quantum of the EM field, and is also called a particle. So, the particles represent the quantized interaction between the EM field and a detector.
There is no concept of a fixed number of photons setting out from Alpha Centauri and travelling in a classical trajectory through space. That is simply not part of the mathematical model in QFT.
What you can say is that the EM field in this case (and in many cases) can be approximated by EM waves travelling through space and obeying Maxwell's equations. I.e. that QFT reduces to classical EM in this case. These waves, however, are not waves of photons. That would make no sense. Instead, they can be modelled as oscillating electric and magnetic fields. Then you are in the realm of modelling light as classical EM waves, rather than as a quantum field.
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 32 ·
  • · Replies 58 ·
  • · Replies 29 ·
