I How does a screw roll down an inclined plane?
The discussion centers on the motion of a screw or cone rolling down an inclined plane, specifically how it behaves under the influence of gravity and friction. It is noted that the screw oscillates or pendulates as it rolls, creating a zigzag motion rather than a straight descent. The participant expresses uncertainty about quantitatively analyzing this motion using mechanics, despite conducting experiments that support the observed behavior. The mechanics of rolling involve the screw pivoting around its apex while the base moves downward, influenced by centrifugal effects and kinetic friction. Overall, the inquiry highlights the complexities of analyzing the motion of non-standard shapes on inclined planes.
Tanreom
TL;DR Summary
How would the motion of a screw rolling down an inclined plane work?
I was thinking about how various objects would slide down on an inclined plane, and I just couldn't figure this problem out.
So let's say I have this screw or cone on its side, on an inclined plane. If friction exists, what would the motion of the screw be as it slides down the inclined plane?
There is no initial velocity and no air resistance either. The only forces acting on the object would be gravity, normal force, and friction.
I know that the screw is apparently supposed to pendulate back and forth as it rolls down, kinda like a zigzag curve, but I'm not sure how that would be...
Edit: I have tried experiments, and the screw seems to oscillate as it rolls down the incline. What I don't know is how to quantitatively anaylze the motion using mechanics.
I imagine the base of the cone would begin to roll downward about its apex. The apex wouldn't move. The effect would be like a pendulum rolling on a plane about its apex.
Or the base of the cone would begin to roll downward about its apex. The apex in turn would be pulled down too, and the base of the cone would track a kind of zigzag curve as it rolled back and forth sliding down the plane.
And some math to go along with it:
https://www.mathpages.com/home/kmath227/kmath227.htm
Have you thought about doing an experiment? An ice cream cone might work, without the ice cream of course.
Tanreom said:
Summary: How would the motion of a screw rolling down an inclined plane work?
Screws and inclined planes are INCREDIBLY easy to come by. Do an experiment.
I have done experiments, in fact. But I don't know how to quantitatively analyze the motion...
Welcome!
I assume the screw is rolling only on its head and tip.
If in static condition, with the tip pointing up, the screw does not slide down the plane, but it does when rolling and swinging, then the centrifugal efect when the tangential velocity of the head is around maximum value, as well as kinetic friction, should be what makes the difference.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
