How Does an Airplane Engine Starter Work?
An airplane engine starter initiates the engine's operation by providing the necessary power to turn the engine's compressor and ignite the fuel-air mixture. The discussion specifically focuses on turbofan and jet engines, which utilize different starting mechanisms compared to piston-driven engines. Resources like HowStuffWorks provide detailed explanations of the starting processes for these types of engines. Understanding the differences in engine types is crucial for grasping how each engine starts. This knowledge is essential for anyone interested in aircraft mechanics.
karim102
Hi,
I want to know how the engine works from aircraft. exacly how it starts. Could anyone explain to me.
Thanks a lot :rolleyes:
What kind of engine? Piston driven prop? Turbofan driven prop? Jet engine?
ok man, I want to know Turbofan and jet engine
thanks berkeman
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
