How does an electric field create velocity in a water bridge?
The discussion centers on the movement of water in electric fields, particularly in the context of water bridges and electrowetting. A key point raised is the confusion surrounding how polar molecules, like water, move when they can only rotate in an electric field. One explanation suggests that polarization causes water molecules to experience a net force due to the proximity of positive and negative charges to the electric field source, akin to Van der Waals forces. Additionally, the phenomenon of autoionization in water is highlighted, where water molecules dissociate into hydroxide and hydronium ions, which can migrate under an electric field. This self-ionization contributes to the overall behavior of water in electric fields. A referenced article discusses how droplets on hydrophobic surfaces are influenced by various forces, including electric field force, which may provide further insights into electrowetting dynamics.
HelloCthulhu
I've been researching water bridges and electrowetting to learn the effects of electric fields on water molecules but something continues to confuse me: if polar molecules can only rotate in an electric field, how is the water moving? Anyone familiar with this phenomenon? Any help is greatly appreciated!
https://www.academia.edu/18092509/B...trohydrodynamics_of_the_floating_water_bridge
Chemistry news on Phys.org
Quick guess is that the polarization places negative or positive charges closer to the source of the electric field, causing the molecules to experience a net force. Similar to the Van der Waals force between closely spaced atoms/molecules. Not sure if that's correct or not, so I hope someone with more knowledge on the topic can answer.
Likes HelloCthulhu
Water (even completely pure water) isn't just water molecules. It undergoes a process called autoionization, which very simplified looks like
$$2H_2O \rightleftharpoons OH^-+H_3O^+$$
with the caveat that these species are actually significantly more complicated than the above equation makes them seem. The point is that water self-ionizes (this is the reason that water has a pH at all), and it is these ionic species that migrate under the influence of an electric field.
Likes jim mcnamara and HelloCthulhu
I'm not sure if this will help, but this article, "Dynamics Behaviors of Droplet on Hydrophobic Surfaces Driven by Electric Field" (2019), describes in section 3. Results and Discussion that a water droplet on a substrate within an electric field is "mainly affected by the inertial force, viscous force, electric field force, surface tension and substrate adhesion". Granted the surfaces are hydrophobic, but I thought the data might still be useful since I'm interested in electrowetting as well.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC6915515/
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
