How Does an Electric Motor Work?
An electric motor operates by utilizing the interaction between magnetic fields and electric currents to create motion. The spinning wheel in the discussed motor aligns with the magnetic field lines, and when current flows, it causes the balls to heat up and deform asymmetrically, resulting in movement. Initial motion is required to start the process, as demonstrated in the video. Despite its interesting mechanics and ability to achieve high RPMs, the motor's efficiency is notably low, limiting its practical applications. Overall, the discussion highlights the complexities of electric motor functionality and its theoretical implications.
SirR3D
Can anyone explain how this electric motor works?
www.youtube.com/watch?v=i7LOF1GZpdo
The spinning wheel is parallel to the magnetic field lines produced by the current through the shaft so what exactly drives this?
I've read the wiki article (link) From what I've understood, you first need to roll the wheel in the direction you want. When the current flows through it, the balls get warmer and get asymmetrically deformed which causes it to move. It also says that it has no practical usage because of its insignificantly low efficiency.
(I think the german article was more understandable. And in the english article it says the effect can also be explained without the thermal effects.)
Likes mfb and berkeman
yes you do, as was done in the video
if that is correct ... it's a reason I would have never have thought of
Quite an interesting demo, it got up to a really high RPM !Dave
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
